Heat Pump Federation
Menu
What is Ground Source Energy?
The ground – mother earth – acts as a very large store of heat energy. It can be used as a heat source in winter, or a heat sink in summer. The ground can be used to moderate the temperature in buildings standing on it.
A ground source heat pump can be used to extract heat energy from the ground in winter and to transfer the heat into buildings. Equally it can be used to provide a very efficient mechanism for heat to escape from buildings down into the ground in summer.
What is Geothermal Energy?
The term "Geothermal" is derived from Greek and means "heat from the earth". "Geothermal Energy" is normally used to refer to high temperatures from deep in the earth of sufficient intensity to boil water. In Iceland and other volcanic regions these temperatures can be found close to the surface of the earth and can be used to generate electricity as well as to provide heating to buildings close by.
For marketing reasons the term "Geothermal" is often use in the United States to refer to extraction of low temperature heat close to the surface of the earth by "Geothermal Heat Pumps". In reality the heat available at depths of five to a hundred metres in normally very close to the Mean Annual Air Temperature at that location at the surface: the origin of the heat is solar energy.
This page uses the term Geothermal Heat pump as synonymous with Ground Source Heat Pump for those who like to use the term "Geothermal Heat Pump".
What are Geothermal Heat Pumps?
A ground source heat pump provides a clean way to heat buildings, free of all carbon emissions on site. It can make use of solar energy stored in the ground to provide one of the most energy-efficient ways of heating buildings. Solar recharge of the ground is an integral part of ground source energy which is used to increase the efficiency of ground source heat pumps.
Ground source heat pumps are suitable for a wide variety of buildings and are particularly appropriate for low environmental impact projects.
They can be installed anywhere in the UK, using a borehole or shallow trenches or, less commonly, by extracting heat from a pond or lake. Heat collecting pipes in a closed loop, containing water (with a little antifreeze) are used to extract this stored energy, which can then be used to provide space heating and domestic hot water. Heat pumps can also be reversed in summer to provide cooling.
The only energy used by a ground source heat pump is electricity to power the compressor and the circulation pumps which transfer heat energy from the ground into the building. A well designed ground source heat pump installation will deliver three or four times as much thermal energy (heat) as is used in electrical energy to drive the system. For a particularly environmental solution, green electricity can be purchased.
Ground source heat pumps have been widely used in North America, Sweden, Germany and Switzerland for many years. Typically they cost more to install than conventional heating systems. However, they have very low maintenance costs and can be expected to provide safe, reliable and emission-free heating for well over over 20 years.
Ground source heat pumps work best with heating systems which are optimised to run at a lower water delivery temperature than is commonly used in radiator systems. As such, they make an ideal partner for underfloor heating systems.
The Advantages of Geothermal Heat Pumps
Ground Source Heat Pumps save money. Heat pumps are much cheaper to run than direct electric heating systems. GSHPs are cheaper to run than oil boilers and can be cheaper than runing gas boilers.
Because heat pumps can be fully automated they demand much less work than biomass boilers.
No need to managed fuel deliveries. No risk of fuel being stolen.
GSHPs require less maintenance than combustion based heating systems. They also have a longer life than combustion boilers. The ground heat exchanger element of a ground source heat pump installation has a design life of over 50 years.
GSHPs safe, silent, unobtrusive and out-of-sight: they require no planning permission.
Ground source heat pumps are the only reneweable energy technology that can benefit from the thermal energy storage properties of the ground to recycle heat from summer to winter.
A well designed ground source heat pump system is likely to increase the sale value of your property.
Geothermal Heat Pumps in Commercial Buildings
Ground source heat pumps are very well suited to commercial buildings, especially those which have a need for cooling in summer as well as heating in winter. However, expert design and installation are critical in achieving high carbon savings and low running costs.
Renewable Heat Incentive
The Renewable Heat Incentive is a financial encouragement to install ground source heat pumps.
Ground source heat pumps have a key part to play in meeting the UK's binding renewable energy targets by 2020.
Performance of Geothermal Heat Pumps
The performance of a heat pump is measured under standard conditions as the "coefficient of performance": this measures the heat output in kilowatts in relation to the electrical input in kilowatts. However, the CoP of a heat pump is greatly influenced by the output temperature delivered to the heat distribution system in the building and the input temperture from the heat source.
In cold conditions a ground source heat pump with access to a temperture of 10°C from the ground will deliver a significantly higher CoP than an air source heat pump with access to -5°C from ambient air. The design, installation quality and controls of a ground source heat pump installation are critical to achieving good performance.
Installation of Geothermal Heat Pumps
A well installed ground source heat pump installation can provide sustainable energy over the whole life of a building.
Menu
