Heat Pump Federation
Menu
Ground Source Heating & Cooling Guide
Ground source heating and cooling (GSHC) systems use energy stored in the ground to heat or cool buildings and provide hot water. Some electricity is used to power the heat pumps but they can typically provide three to four times the amount of heat as the electicity used for heating, depending on their design. They can provide much more efficient cooling than roof mounted chillers because they heat exchange with cold ground instead of hot air.
The HPF Ground Source Heating & Cooling Guide was launched at Ground Source Energy Expo 2017. The original guide was first published in 2011 by the Environment Agency to provide information, advice and guidance to prospective users of the ground source energy, their consultants and contractors. The guide focuses on good practice rather than regulatory requirements.
It was originally written in collaboration with the HPF with additional input from other industry stakeholders and is now published, with significant revisions, under the HPF banner.
The HPF Ground Source Heating & Cooling Guide is available to be bought from CIBSE.
If you are a member of the HPF we can send you a copy of the Ground Source Heating & Cooling Guide if you: click here.
Menu
